The two side engine mounts on my '66 100hp appear to be shagged bcos they dont stop or dampen any front to rear engine movement when under load.
Ive found a drawing of the mounts on marineengine.com & it appears that the rubber has broken from the metal plate at the bottom of it & now it just slides back & forth.
Does anyone have any tips of how to replace these mounts in the easiest way?
Will i have to undo all the nuts/bolts at the bottom of the engine & lift the powerhead off to replace them?
I thought id ask on here before i just got ahead removing the bolts & trying to rip it off.
