Replacing alternator
ericcarr2000
Ensign
OK as many of you may know I am in the process of repowering my Sundancer. I found out that my alternator is bad. it has Mercury Marine Part number 12449 does anybody know where I can get a Nice chrome replacement?
harleyman1975
Ensign
Take a pic? if it is a delco style chrome cases are available otherwise you may have to have it plated yourself.
I dont know if I would put chrome in an engine compartment unless you like polishing and waxing to keep the chrome from tarnishing and pitting.
ericcarr2000
Ensign
I don't mind polishing the chrome at all. The problem I'm having is my current alternator has the regulator mounted on the back of the alternator.
Do I necessarily have to have an alternator with the regulator on the outside?
Ayuh,.... You can use any Marine rated alternator,.... if it'll mount up proper,....
NHGuy
No but you can use bigger.
Or snoop around the net for parts and redo it your self. I remember there were auto electrical shops that specialized in this type of stuff. it's becoming a lost "art".
The Mercruiser guide tells how. You'll' want to get the diode trio, brush & holder, probably bearings, maybe pulley. The case and windings don't fail unless dunked and rusted badly.
Or you can just buy one all made. American &/or "real" brands cost $`150 to $250. Overseas stuff $80 plus ship. I used a cheapie starter at one point while I had mine out for a recondition. It had got wet when I got water in the bilge from a lost plug. Never did put the OE back, it's sitting on my shelf rebuilt.
Whichever way you go, put a screwdriver or wrench on all the external fasteners you can reach to verify they are snug.
