further
- Jun 18, 2009
- 1,038
Hi all,
Newbie to wiring and trying to get all my lights and other accessories to work (horn, stereo, etc) on my 1988 Maxum 1700. I've tracked it down to the fuse panel and replaced all the fuses and still no luck. I removed it and tried cleaning with steel wool and sandpaper but still can't get all the terminals to work well so I figured I should replace it while I have it out. Question is what should I replace it with? I'm assuming I should go with the blade type but not sure which would work with the setup I have. I've attached a photo of it. Can you all recommend a replacement that I should get?
Thanks much!
Thanks much!
