wbeaton
Thread starter- Joined
- Jul 30, 2006
- 2,332
I have a 1968 Mercury 39 3.9 hp outboard with a cooling issue. I replaced the impeller and checked to make sure the water passages were clear, but it still didn't pump any water. I put the lower unit in a bucket with the entire water pump underwater and turned the driveshaft with a drill. It wouldn't pump water more than an inch or so. I then replaced the entire water pump housing even though it appeared to be in good shape. It still won't pump water. What am I missing?
The driveshaft is a little rusty at the water pump. I cleaned it up with sandpaper and it seems ok. Could this be causing a loss of pressure? Any help is appreciated. I've never run into this before.
