Replaced throttle cable need adjustment help
jmymarch
Hi I replaced my throttle cable on my 2000 crownline 180 bow rider after replacing manifold now when I put in forward in locks counter clockwise and spins freely as it should, neutral spins both directions, when in reverse it locks clockwise but will not spin freely in counterclockwise direction as it should any help much appreciated. I measured distance on thumb screw assembly to 6" as directed.
Ayuh,.... Welcome Aboard,..... It's yer Shift cable ain't it,..?? Not the Throttle, that hooks to the carb,....
Probably the Lower shift cable,..?? from the motor to the drive,..??
Not the forward cable, from the controller to the switch plate,..??
