Re: replaced rectifier and it still is not charging.
The fact that the tachometer functions when connected to the yellow lead of the stator proves that the alternator is functional as the tachometer operates off of the alternator's 6 pulse system.
To check the stator with a ohm meter, disconnect the yellow leads.......
On high ohms... connect the meter leads between those two yellow leads. The reading should be infinite.... looks like a dead short.
Still on high ohms... connect one meter lead to a yellow wire, the other meter lead to ground. There should be absolutely no reading. Connect the meter lead to the other yellow wire. There should be no reading there either.
Meter on low ohms... Again connect meter leads between the two yellow leads. The ohm reading should be very low... not over 1.0 ohm.
What readings do you find if different?
The rectifier.... I assume this is the water cooled voltage regulator/rectifier assembly type unit? If so, are you sure you have it wired correctly as per the wiring diagram in your service manual? Positive (+) voltage being applied to the RED wire of the unit?
my results were:
On high ohms... connect the meter leads between those two yellow leads:
0.00
connect one meter lead to a yellow wire, the other meter lead to ground.:
0.00
Meter on low ohms... Again connect meter leads between the two yellow leads. The ohm reading should be very low... not over 1.0 ohm.:
02.6
I assume the last reading is a "bad" readin and indicates a problem, does this mean the stator is bad, is this the reason the charging system is not working, and could this be the cause of the "mis" when the motor is running.
as far as if I wired it correctly, I wired it accoding to the manual, but there is an issue with the 2 yellow wires, the manual calls for a yellow wire and a yellow/gray wire..neither yellow wire has any gray on it so I am not sure if those two wires are in the right or wrong places. I was gonna switch them, but I know the rectifier is sensitive so I put it back on the way it came off. keep in mind it was not charging when I purchased the boat and I do not know if the P/O wired it correctly. also there was a third purple wire not mention an any schematics I looked at (it goes to VRO which is disconnected) I left the purple wire off.
