Replace water intake valves?
Tectonator
Hi,
I've been lurking for some time now, and finally have a question of my own: Should I replace these valves?
They belong to my 28' fiberglass 1966 Luhrs Alura (twin) in which I'm just starting a rebuild.
Boat is on land and motors are out.
Pictured are the two intake valves for the twin Chrysler 318's and the water intake valve (1.5", I think) for the head/livewell. I believe these could be the original valves. With the exception of the valve missing a handle, the other two turn freely. Is this setup acceptable or do I need new seacocks with ball levers?
Also, what are the two brass "balancer" things on top of the motor water intakes?
Thanks in advance!
Dave
alldodge
:welcome: to iboats Dave
IMO if the gate vales work and function properly they can remain, if they are suspect, I would replace them now. The two things are old style and can be used to pump antifreeze in during winterization or fresh water flush by closing of the gate valves below. There may even be a screen in there to help protect the water pumps.
fetch
Tectonator
Thanks for the reply! Very helpful.
I had no idea what those things were used for. I will probably remove the thru-hull valves to replace the wood
they are sitting on with new, but all these bronze pieces look pretty strong.
