Can't say that I've done a 1983, but it really doesn't look much different than older ones that I've done plenty of. The general procedure is remove the clamshells from the lower mount and the nuts from the three upper ones. You don't have to totally remove the nut from the upper front one, but back it off several turns. Remove the vertical throttle shaft for ease of reassembly, and the fuel hose. Then swing the lower unit rearward and lift the whole motor up and out of the steering bracket. It will be much easier if you have a hoist of some kind to lift it.
