Re: Replace deck on A 1968 GLASSTRON V156 TRI HULL
Hi Plaz,
When i ripped the deck up there was lots of water soaked foam blocks which were not attached to the hull. I've been reading around on the forums and find that a lot of people don't bother to put foam back in when replacing the deck. Maybe i will do the same as they hold water and hence add weight. However it might be required by law in your area.
Yes the deck was resting on the high spots on the hull nearest to the walls. The stringers and ribs gave support in between.
I am wondering how much water might get under the deck. Maybe i should put holes in the stingers and ribs to allow drainage to the splash well. These holes would need to be sealed somehow so the wood doesn't rot. I noted some drainholes in the most forward rib under the cap. I guess the foams was meant to soak it up.
Mav
Mav
Hi Plaz,
Mav
Mav
