Sea Rider
Thread starter- Joined
- Sep 20, 2008
- 12,345
Scenario :
Small marine facility
310 Rib shuttle transporting boaters from pier to moored boats and viceverse.
Tohatsu 2 strokes 18 HP engine
Distance : 50 meters at the most
Water conditions : flat calm waters till noon, choppy then after
Fuel/Gas ratio 50:1
A rib/engine combo for tender use will be used repetitively at non planing speeds mainly because it’s small size, passenger load & short distance, was wondering if lowering the fule/oil ratio to 60:1 would benefit the plugs from fouling and engine smoking much less than operating at normal 50 :1 ratio ?
Assume that with 60:1 safe ratio will still be able to plane the rib in morning flat calm waters with just driver and copilot, going full wot for quick plane and then back down to ? to ? throttle to maintain plane for some minutes and plugs free of fouling untill next repetitive idle operaqtion is required. Thoughts, experiences are welcome.
Happy Boating
Fuel/Gas ratio 50:1
Happy Boating
