misterfroggy
Thread starter- Joined
- Oct 20, 2015
- 16
Just started work on a LoneStar Riviera. it's an 18' riveted aluminum semi-V hull. Some of the rivets have started to leak...
I've repaired rivets on jon boats with JB weld and they've lasted, but this hull will take more of a beating and I'm much more concerned with the repair on his boat being permanent.
I've done some digging around here and elsewhere on the internet and have a few questions. First, has anyone ever used these brazing rod-like things? https://www.youtube.com/watch?v=f_4x3TmHs6M
I would bet it has some of the same pitfalls as welding but since it's aluminum to aluminum and it's a lower heat (i assume), I don't know if that makes a difference.
Second, the best thread I found here on iBoats is this one: http://forums.iboats.com/forum/gener...-repair-rivets
There is one poster claiming that screws and nylon washers are the best repair and that it's a watertight, permanent repair, whereas other posters suggest that re-riveting is the best way. Still others suggests that bucking the rivets is just fine, although I get the sense that simply bucking isn't a permanent solution.
One poster said that, in his experience, stainless screws rusted, even though they were above the water line in a freshwater lake.
I am happy to go through and do the screw and washer method if it's the best, most permanent fix, but I'm also happy to buy a pneumatic riveter or something and re-rivet the whole thing if that's the best, most permanent repair. Also wouldn't mind JB welding it or something (this is not a show boat by any means) if that's just as permanent. I'd rather spend a long time NOW and use the right tools and proper method to do it RIGHT. and, hopefully, do it just once!
I couldn't bring myself to arrive at a conclusion as to what best way based on that threads I've read, and, since that one is 7 years old, I figured that maybe I could start a new thread on the topic and hopefully benefit from the experience of 7+ extra years of hull repair and new technologies and such, and see if there is a consensus on the best way to repair a riveted aluminum hull.
Any insights, guidance, thoughts, etc. would be very much appreciated.
Thanks!
EDIT: I guess I should ask... How reliable are rivets, generally? I think I have only a few leaky rivets and this boat is 60 years old. Should I repair just the leaky rivets, or go through and re-rivet or rescrew everything, since I'm going to be doing a few anyways?
thanks!
Thanks!
thanks!
