Repair manuals - which ones?
joed
I have two 1995 mariner, 9.9 and 60. Which repair manuals should I get so I can properly change the water pump impellars? I see some users here recommend against the Seloc because they are not always correct.
Where can I get proper Mariner manual and will I need two different manuals? Canadian sources would be best but I do have USA drop I could send them to.
thanks
Windykid
Re: Repair manuals - which ones?
I dont think you can go wrong with OEM manuals.
joed
I found the manuals at the Mercury site. They want the serial # to order the manual. I don't have them handy right now. Will I need two sets of manuals for these engines? I can't tell from the Mercury site what is included in each manual. Is it just one engine is it one year of all engines?
njwhaler
I just went through the same process myself. Read the first part of my thread. I would call to the publishjing dept. and ask then to pull the manual and find the section you need to make sure its there. They dropped the ball on my motor's manual. No procedure for the carburetor is in the damn book, yet it references one as if it exists. Check it out:
http://forums.iboats.com/showthread.php?t=199433
