anjp
- Mar 26, 2014
- 4
I was recently given an old Grew 140 SS. It's a 1980-ish, 14.5 ft fiberglass runabout that I plan to use for fishing. I'm well aware that it isn't anything to write home about, which is why I want to spend minimal money and energy on this repair... Oh, and I've got another thread going to try and revive the 1981 Merc 50
Apologies for these pics. They were taken in my dark garage
1- http://i822.photobucket.com/albums/zz145/anjp/Grew Boat/grew_transom_1.jpg
2- http://i822.photobucket.com/albums/zz145/anjp/Grew Boat/grew_transom_2.jpg
3- http://i822.photobucket.com/albums/zz145/anjp/Grew Boat/grew_transom_3.jpg
4- http://i822.photobucket.com/albums/zz145/anjp/Grew Boat/grew_transom_4.jpg
There's a large crack on the bottom left side of the transom (where it meets the keel). See photos above. There's also a crack on the top of the transom where the outboard motor bracket would be. My theory is water got in from the top and soaked through the plywood. It froze and expanded in the winter (I'm in Ontario) and split the fiberglass near the keel. This could have happened a season or two ago because the guy who gave it to me didn't take very good care of it. I know water damage in the transom usually means rot, but in this case the plywood frame is still solid and hard. No sagging, play, or loose bits when I poke around. I'm sure the correct repair would be to cut out the transom and replace the entire thing, but that's just not going to happen in this case. I'm looking for a fix that will get me through 1 or 2 more seasons before this boat goes to runabout heaven.
My initial thoughts are: dry the plywood thoroughly. Then epoxy coat the top part of the transom to waterproof it for future. Next, cut a 1/16" thick sheet of aluminum to fit the back face of the transom. Screw it into the wood to in order to close the fiberglass gap. Then waterproof the crack with a combination of CSM and epoxy. Obviously I'm talking about a patch job here and not a professional repair. Thoughts?
cheers
cheers
