Repair a circular saw cut in the hull
Status
Not open for further replies.
Bvc
When taking some of the old floor out the adjustment came loose on the saw and went through the bottom of the boat I read two layer with fiberglass cloth and resin on the inside but what should I do on the outside before I gel coat it it's just the width of a saw blade about a foot long
tpenfield
Happens on this forum a few times a year. You do want to repair from both inside and outside, as well as filling the void from the saw blade.
you should do it from both sides. bevel the cut, then a layer of CSM on each side, then a layer of 1708 (assuming poly) on each side. fair, then sand smooth, then gel coat.
alldodge
Agree both sides, but use epoxy resin and on the inside use an additional piece of plywood and cover. Epoxy will bond to everything where poly needs help
Woodonglass
Duct tape the outside. Use thickened resin to fill the cut from the inside. (We call it Peanut Butter. Resin, Thickening Agent, With Poly use Cabosil and 1/4" chopped milled fibers, With epoxy you can use Sawdust or cabosil. Mix to the consistency of creamy peanut butter.) Once cured, sand/grind from about 3" away from the cut towards the cut and feather the middle. Apply a 1 1/2" wide layer of 1708 and then a 5" patch. On the outside use two a layer of CSM and then a layer of 1708 applied Fabric side down and CSM Side towards you. Sand, fair, Sand and apply gelcoat or paint. Done. This should take about an hour and a half from start to finish.
You can use epoxy if you want but...You can use poly resin too!
It's more than sticky and strong enough to do the job.
Status
