Removing Transom/Gimbal Housing- Mercruiser
Status
Not open for further replies.
rstier
Hi,
Is it possible to remove the Gimbal Housing (Alpha One) and Transom as one unit or do I have to take the Gimbal Housing off first?
Thanks,
Ron
Don S
Re: Removing Transom/Gimbal Housing- Mercruiser
Just so we are all talking the same parts here.
rstier
I believe I meant to say:
Do I have to remove the Gimbal Ring to remove the Transom Plate assembly?
Don S
Nope, it's actually easier to get the gimbal ring off AFTER removing the transom shield (Gimbal housing) from the boat.
rstier
Ok, good.
Thanks!
karl in florida
I need to remove my transom plate / gimbal housing as a rusted u-joint tore it up, do I need to remove the engine to replace the (exterior) transom plate?
Thank you, Karl
Don S
Yes, you have to remove the engine. In the future, it's best to start a new thread of your own, not the end of an old post. Won't take long and your question will be buried in the middle..
Status
