Removing Suzuki DT40 prop shaft housing ??
barbadosbeginner
I have an old Suzuki DT40K outboard, serial numer 4002-605316.<br /><br />The whole lower unit has seized up due to salt water getting in and I can't remove the prop shaft housing. Is there a technique or a special tool I need. The local machinist applied heat and some of everything else and can't get it out. Could there be something else holding it in?<br /><br />HELP PLEASE.
