Removing Cam shaft / Valve clerances
adam125
HI All
I am about to remove a CAM shaft from my Mercruiser 4.3 v6 1998, I have already removed the heads and the drive chain and sprockets before I step into the unknown could anyone please advise me on this task ?:)
I also I have a second question it is possible to set the valve clearances on this design as I have cam lifters and push rods there doesn't seem to be a way to set any type of clearance or is the clearance just set on a torque setting ? or is it to do with the tension on the spring inside the lifter?? any help on this would be much appreciated :)
achris
More fish than mountain goat
Re: Removing Cam shaft / Valve clerances
Do you have the genuine Merc factory manual? All the answers to your questions are answered in the manual...
Chris.......
BTW, for the right manual, we need engine serial number. 1998 was a 'cross-over' year for the manuals, so to get the right one....
adam125
Ahh ok I have a manual not sure if its genuine here is my serial number L015957 if you could point me in the right direction to one that would be brilliant :)
Thank you
Adam
achris
Interesting... You have a 1998 engine, but it fits in the 93-97 serial number range for the manual... :noidea:
HERE is the manual... D/L and Ctrl-S
When you're looking in the manual, your engine is a 'Gen +'...
Chris.....
adam125
hmmm strange wouldn't have a clue why I have only owned the boat about 9 months so not 100% on the history :) Thank you Chris il let you know how I get on :)
Bt Doctur
I have a pipe around 1 1/2 feet with a threaded bolt welded on the end to screw one of the camshaft gear hole. pipe acts as a long handel
