Keyboardman
- Sep 10, 2015
- 364
Hi all, I've pulled many automotive engines but this is my first marine engine I'm replacing. I'm guessing that the intermediate housing comes out with the engine as a unit and then separate it from the engine after removal? I can see two large mounting bolts and nuts, is that all that holds it back to the transom? Also should the outdrive be in the up or down position or does it matter? Thanks.
