remote control issues
kerbz
hi i have a 1978 procraft 15 ft bass boat with a 1977 75 hp evinrude there is a small button on the inside of the remote control that when not depressed will not allow the motor to crank. i was wondering what it may be and how to fix the problem
Honorary Supreme Mariner
Are you saying the motor will not start or the motor will not turn over with the key ???
kerbz
it will not turn over with the key with out the button in question being depressed
poconojoe
What happens when it starts and you let go of that button? Does it stay running or stall out?
bonz_d
The only button I know of on an OMC remote is the dead man's switch. Same as on jet skis and snowmobiles. Usually there is a clip with a lanyard.
F_R
Start-in-neutral-only switch. The button is depressed when in neutral, allowing it to start. But not depressed in gear, so it won't start.
bonz_d
You got a picture of that? Can't say I've ever seen one.
Excuse me once again. Reread this and the switch is inside not on the side. So now I agree.
