1983 Bass Tracker Tournament Tx w/ 1983 50hp Merc
I have some cracks in my transom between the upper and lower motor mounting bolts. The wood feels solid and dry but I'm sure there is some wet/rot some where as it is the original. I plan on having it checked ASAP, is there anyway to reinforce the transom to get through about another year? I was thinking a square of heavy aluminum to more evenly distribute the weight?
The wood on the outside of the transom is really soft so it doesn't appear to be providing support. Replacing the exterior wood and adding an aluminum brace both seem doable and cost efficient for now. Will this be safe or should I keep the boat off the water until i can have the whole thing replaced?
I know the best thing to do is to replace the transom but as a college student, that isn't an option until after graduation.
