jeff francis
Thread starter- Joined
- Feb 27, 2016
- 10
I have a 1977 evinrude 175 and was wondering what the rectifier does exactly
Jeff
Jeff
wires from part 64 go to part number 44 that is covered by part number 51 so i guess I just need to buy a new rectifier and run accodingly
Thank you!! Yea I was looking at the CDI part and also the Sierra part which is half the price but I,m going to get one of them and install it next week.Yes that's right The red wire is the DC+ output from the rectifier. The two yellow wires are the AC input. The case of the OEM round rectifier is the DC negative.
Some after market replacements may have a black wire which is the DC negative and must be grounded.
If you run for prolonged periods You may like to consider a regulated rectifier ( eg CDI part 193-3408) which will avoid any risk of overcharging the battery.
For further details see http://www.cdielectronics.com/product/rectifiers-regulators/johnson-evinrude-regulated-rectifer-193-3408-replaces-580795-581603-582307-582399-583408-18-5708-9-17200-9-17200-9-17200-9-17200-9-17200/
When you have fitted your new rectifier check that is working by monitoring the battery volts. A fully charged battery should be about 12.7 volts. When you crank the engine the volts will fall but if the charging is good should quickly recover and increase, as the battery charges, to 14.4 volts in the case of the regulated rectifier or to a higher value if it is unregulated.
Keeping your battery properly charged will help towards a long life for it
If the wire is broken were it enters the rectifier - A new part is needed. If the wire is long enough to crimp a splice to rejoin the wire, you might be able to salvage the rectifier.
Thanks everyone!! Now for the next question. I had my carbs rebuilt but more times than not when I go to get on plane my wants to bog down and sometimes shut down other times I have to jockey the throttle back and forth to get on plane. It has a new lower fuel pump but I'm thinking about putting a new upper pump on it. I bought this boat to refurbish and keep from paying out the a#$ for another boat. What ya think
Jeff
yea everything is new but I may change it all out again, it's my wife money!! lolIs the fuel supply hose a 3/8" hose? Not unusual for the fuel primer to go bad in the hose. (sometimes the ball valves go bad, and won't flow fuel.) Make sure the primer bulb arrow is pointing an a generally "upward" orientation. Some old bulbs won't work correctly if the arrow on the bulb is oriented downhill in the splashwell at the back of the boat.
