Redoing wood floor the proper way round two
Status
Not open for further replies.
Alloy Cruiser
Banned
It has a very long shelf life
what is the pot life of your solution?
1.
Actualley I was curious how quick the solution after mixing stayed in liquid form before it hardens in mixing container?
2.also is there a procedure (order of ingreints mixed)?
3. how long should it be mixed?
4.I assumme you mix by hand? I was thinking for a thougrow mix bend a rod kindof like a muffin dough mixer and attach to drill .
I should be receiving last ingreint marine varnish today anxious to seal wood.
my new plan is completely seal w/ your solution then cover (protective topside of board w/ layer of total seal expoxy) like will expoxy stick to hardened solution?
edit I have small bag of pureified sand anti slip paint additive,http://www.homedepot.com/p/BEHR-Prem...7024/202301601 can I sprinkle it in on last still tackie coat?
thanks Wood and others for advice
jbcurt00
Closed
Read and reply to my PM from either of your user accts, which is not permitted by the way.
Status
