Alloy Cruiser
Banned
- Jul 13, 2017
- 8
Redoing wood floor the proper way round two
First time around I trusted rustolium they told me marine topsider paint sealed wood they lied.
https://www.ebay.com/i/391599253323?chn=ps&dispItem=1
Wood I used
https://www.lowes.com/pd/Top-Choice-Blondewood-1-2-in-Birch-Plywood-Application-as-4-x-8/50121137
thinking round two will this use this to seal PW
https://www.amazon.com/dp/B00HR8517A?th=1&psc=1
?1.will a quart be enough to cover a full sheet of PW?
Plan to use same plywood.
I need to redo two pieces aft. (will start w/ the middle piece) Most then middle (1/2 of middle piece is inside ? outside)
Vessel has two longitude stringers w/ a 27? gap in the middle initially the ?? PW had no flex.
?2. is it recommended to add latitudalle supports in-between stringers? I?m concidering adding a stringer?
The original floor seams where joined w/ a 2? aluminum stripe I believe was designed to keep seams tight, not so much for support. Edit vessel was originally built w/ 5/8?PW
?3.is ?? PW thick enough?
First round for middle piece I messed up and covered it w/ spar urethane it didn?t take a couple months and it was rotten (vessel was exposed to rain, now I have a storage rain blocker cover).
?4.can I smear a couple coats of this sealer and call it a day? then expect it to last a few years?
or must I add fiberglass matting to the sealer?
I will definitely use PW for the middle piece will problley use a big piece of aluminum for aft flooring (which is actualley laying on top of rotten aft PW) then cover the outside piece w/ this
https://www.amazon.com/dp/B00GWCA7L...t=&hvlocphy=9012826&hvtargid=pla-307349613577
there?s usalley a good amount of slippery blood and fish slim on aft deck.
?5.will the rubber flooring be difficult to clean?
Plan to secure PW to stringers w/ aluminum revitos.
iboats wont allow images
Thanks
Wood I used
Thanks
