rebuilding surge brakes master cylinder question
horizona
cleaned up and amm reassembling my triton surge brake actuator. There are two fluid holes in the bottom of the actuator tank. the large hole is cleaned out and fluid flows freely. The other hole furthest from the plunger rod is clean but rust blocked. I need to drill it out. How big is the diameter of the hole. I pierced the rust with a pin but i do not know how big it should be. Thanks
