reassembling carbs j50pleea late 90's outboard
bobble
Well, I cleaned and rebuilt these like a month ago and they have just been sitting, and I forgot which hose goes on which nozzle of the carb. There are two small lines coming from the engine, two larger lines coming from the fuel filter and pump.. One larger line coming from the bottom of the engine. Than I also have one random larger hose, the same size as the other larger ones, that i detached completely for whatever reason. I assume the two smallest size lines go with the two smallest nozzles on the carb but where do the rest go?
Also, how does the throttle link into the carb? A link to a service manual would be excellent at this time. Any help is appreciated.
Pictures of the carb:
http://postimg.org/image/ewannkbnz/
Throttle:
http://postimg.org/image/hhhytq9g1/
Sorry for links, says invalid file when I try and upload...?
tommarvin
Ensign
I don't have a link, but I would buy a service manual. Or the hoses were already cut to fit for a specific location, and you just do your your best to put them back is this a supply hose or a out hose? Fuel in fuel out the two smallest nozzles, its one way or the other, put the puzzle back together.
Honorary Supreme Mariner
Carburetors are the wrong ones for your motor !----Top carburetor needs to be mounted on the lower cylinder !
tommarvin
Ensign
After you put the top carb on the lower cylinder and the bottom carb on the top cylinder like racerone said, can you figure out where the hoses go now.
