Reasonable Price for 99 yamaha 115 4 stroke?
gfuller40
Hello,
I recently found a 1999 Yamaha 115 4 stroke in really good condition for $2000. Is this reasonable, a good deal even? the engine runs perfect, not sure of the hours, used in both fresh and salt water. Any opinions are greatly appreciated!
Thanks!
NYBo
Re: Reasonable Price for 99 yamaha 115 4 stroke?
According to the NADA guide, no such motor exists.:confused:
However, according to that source, the price is in the ballpark for a '99 Yamaha 2 stroke , 4 cylinder, 115 HP motor.
Whoopbass
I think its a good deal.
I would have it checked out by a mechanic before I laid down the cash.
I wouldn't go by anything NADA has listed for a price. If I could buy motors as cheap as they value them I would be a millionaire.
kenmyfam
Hello,
Thanks!
All depends on overall condition. The number of hours on a motor are not as significant as how the motor has been used, serviced and maintained.
Make sure compression is good and all cylinders are within 10% of each other.
A good hours test run on the water will tell you a lot if that is possible. If not it should at least be run on muffs.
Welcome to iboats
gfuller40
I did notice that NADA did not have that engine listed, however, I went to a yamaha site and it did. Regardless, they do always list engines ridiculously low!
Unfortunately I cannot actually test this engine out on the water because I'm in Maine and everything is frozen solid with the exception of the ocean. The owner says he did a comp test and each cylinder was right around 130psi (I'm still going to bring my gauge and test it myself).
I also came across an 88 evinrude 140hp running with good compression, never used in salt water. I'm checking it out tonight, the guy is asking $800 for this engine. I know these are two completely different animals here but they both seem like decent deals. I just don't want to make a $2000 mistake... $800 would not hurt as bad.
NYBo
Yeah, NADA prices on outboards sure seem low. After my earlier post, I looked up the motor I bought last year ('87 Force 85 HP, power T&T). They don't list it with power T&T for '87, but have it for ''89, with a price of $100! Either I got ripped off or they are way off.
But if their pricing for Yamahas is equally off-base, $2000 would be a steal if the motor checks out.
gfuller40
Here are some images of the engine
gfuller40
I think they are indeed way off. I have an 86 force 85hp and it will run, but the 3rd cylinder will kick in and out. It's been to the shop 3 times now and it keeps happening, Not sure what is going on with it, that's why I'm going for a newer engine.
I've seen these yamaha's going for ridiculous prices (or people asking ridiculous prices anyway) I've seen them for sale generally around the $4000 mark. For instance someone is selling one on ebay right now with a buy it now price for $4500, but no one has "bought it now". I guess it's one of those things....
sdsaw
From the looks of the picture... that's a 2 stroke
The 115 four stroke is a four cylinder inline motor and I don't believe they were ever made with carbs.
trendsetter240
Uh yep, that is not a 4-stroke motor. See that large, 3/4 full plastic reservoir on the side of that motor? Well it's filled with 2-cycle oil.;)
I liked the 90's Yami 2-strokes. Good smooth running motors. You will want to make sure to check compression as mentioned. Also try and get a water test. That's the only way you will know for sure the condition of that motor.
2k is a good deal if it is in good shape.
cheers
gfuller40
I don't know what I was thinking... It was advertised as a 4-stroke and I was too quick to jump on it, thinking it was a good deal. I went to check it out. I will say that it ran awesome, touched the key and it started from cold, however, when talking to the owner I was told that it was in mint condition, well it wasn't. Scratched, cracked cowl, salt deposits all over the lower unit, mild corrosion, etc... I guess this is expected but again, he said it was mint and that was what I was expecting. So long story short... I didn't get it... Probably should have, but didn't.
sdsaw
Did you check out this one?
You might want to ask for feedback on this motor over on the Johnson/Evinrude section.
The best thing about this motor is that it was never used in the saltwater not to mention the price
sdsaw
I see that you have already posted over there :p
Good luck with finding a good motor!
Home Cookin'
I think I'd go with the Yamaha. However, look at the way your seller keeps his stuff--is it squared away and maintained? Your engine will be the same.
I'd worry about the fact that he called it a 4 stroke. I doubt he was trying to trick anyone; I bet he just didn't know. That lack of knowledge could cross over to his maintenance skills--like did he start it without muffs?
The guy I bought mine from thought you could run the motor on the built-in flusher. That told me he tried but he wasn't all that good. But who knows all of it (except Rodbolt?). I determined that his mistake couldn't hurt the motor, just the water pump which I was replacing anyway, so I took it.
I think you have a good opportunity for a good motor there, and you know there is some risk.
