rear motor mounts
vxtech
1975 mercruiser mc-1 inline 6 ; the steel bushing in the center of rear motor mount in bellhousing surrounded by rubber removable ? or has bushing torn away from rubber. please don't confuse this bushing with the one that goes over on top of motor mount and under bolt washer, thanks chris
Don S
Re: rear motor mounts
The rear mounts do fail like that, and left unchecked will destroy the engine coupler and input shaft on the outdrive.
Yes they are replacable, but you do have to pull the engine to do it.
Head up to the Adults Only sticky and download the OEM manual. It will make the job a lot easier.
vxtech
thanks Don, that kinda confirms why coupler is to low (1/4inch) for proper alignment
