Rear Floor Removal
chefdecuisinedavid
I'm planning toto remove rear deck above engine room on 2000 Larson Cabrio 330.
Anyone in the forum that has done this before?
What to watch for, best method.
Thank you
redneck joe
welcome to the forum.
Someone smarter than me will be along soon, until then:
why?
end goal?
pics are great.
chefdecuisinedavid
why?
end goal?
pics are great.
We need to replace a wiring harness. Solder in a new 9pin pigtail harness, removing floor will give us greater access we will also take the opportunity to clean up entire engine room.
bakerjw
Welcome to iBoats. This is one of the friendliest boat sites out there.
Nice looking boat.
I cannot help with your question but it would help if you added some detail and pictures of the area in question.
Like, is the deck soft? How has the boat been maintained? etc...
Sadly, soft floors tend to be indicative of other issues.
Again,. welcome.
Here is a similar Larson on boat Trader. Has a couple of engine area pics.
Chris1956
Honorary Supreme Mariner
A lot of those style boats are made for the deck to come up easily to allow work on the manifolds and replace the engines.
A lot of them have large hatches that just pop off to allow the kind of access you need.
bakerjw
In this image, I believe that the engines are under the aft deck with the pull ring and seat post. Ahead of that seems to be the low headroom salon/bunk area.
MikeSchinlaub
So you just want to remove the lid? That's easy. The ends of the shocks are held by a spring clip built into the head. You'll see a little indentation under the spring. Stick a small flat head under it and twist to release it. It only needs pulled out a little bit, then you can pop the shock off of the bracket.
After that, just have someone hold the lid while you unscrew it. Might be wood screws, might be machine screws with nuts on the back side.
If only there were screws or something.....
start by pulling all the exposed hardware holding the deck on and pull it. you may need an overhead hoist as that whole aft assembly is probably 600#
Note, some of the snap hardware may be doing double-duty as both snap and deck holding.
chefdecuisinedavid
600 combined? I think they are 3 separate pieces
Lou C
Without removing the whole works can you even put oil in the engines?! Looks like all you can access is the fuel filters & belts. I’d imagine that oil changes and winterizing are real “fun”. The only I/O I’d have is a single engine with a wide open engine compartment. These are what they call “double trouble”!
Chris1956
Lou, it is a real advantage to have the engines under the deck. My neighbor has an I/O with a 8" tall doghouse over the motor. It was a toe tripper every time you tried to walk around.
Lou C
I agree as long as you can get down in there if you need to change a starter etc.
airshot
Being a 2000 model year and 26 years old....do a thorough inspection of any wood structure while down in there. Fiberglass boats with wood skeletons rot from the bottom up. At that age the possibility of wood rot is pretty high and should be addressed while you have things apart. Good luck..
