realigment of flywheel
Doc57
Hi, I have a 1976 50hp mercury motor and have just replaced the power head. during which I removed the top of flywheel has I was having issues with getting the whole flywheel off. I think when I put the cover back on the flywheel it might be out of alignment. Can anyone explain I how I check it that it is correct and how to realign if it is incorrect? thanks
welcome aboard
the key in the crank aligns with the groove in the flywheel.
Honorary Supreme Mariner
NO-----He is saying he took the 8 bolts out for the flex plate !!-------Put # 1 to TDC and use timing marks.-------Or use paint / rust stains on flex plate and hub to see where it was.
Doc57
thanks for your help, if i put # 1 to TDC should can I use the timing marks on the side of the flexplate to line up with the point indicator to ensure it aligned correctly?
