Dingopointer
Thread starter- Joined
- Apr 26, 2010
- 8
I have had a problem with the primer ball collapsing on my boat. It happens randomly - just the ball collapces like there is an obstruction in the fuel feed. I have so far done the following:
When I connect the same primer ball hose to the auxillary tank - no problems once or ever. This is getting insane. There is nothing else left to replace in the fuel line assembly. What can I do??????????
- Replaced: tube that goes into the tank, anti-syphon valve, fuel line, water filter (and the housing for it), primer ball. None of this fixed the problem.
- Pumped the tank and inspected it inside: clean plastic tank - no chunks.
- Tried to open the gas cap when driving boat (to make sure that the tank ventilation is not clogged)
- Kicked the boat and hurt myself.
