Re: Starting problem
plztellme
I have a 1990 50 H.P. O.B. When the boat sits for a day or so, the motor will start on the first crank. After the boat has been run for awhile, it won't start. What might be the problem or a place to start.......coils perhaps?
jerryjerry05
Do a compression/spark test.
Then check the fuel system.
Fuel pump diaphram.J
Jiggz
When it won't start you need to check the following: Spark on the plugs and also if there is fuel in the carbs (prime the bulb if you need to) and then post back.
foodfisher
I've heard of the carb. bowl going dry from the engine heat after a run and shutdown. Will repriming with the bulb allow a start?
plztellme
The bulb was hard and I used to be able to start in the flooded position on my control, but could'nt even do that
Jiggz
So is there sparks when the engine wouldn't start?
