Rayzor
- May 5, 2007
- 172
I put all new seals and o rings in the lower unit on my 1967 merc 50 hp. After a brief run around the lake my reward is milky oil. So made a psi tool and put 10 pounds to it. The leak seems to be coming from the large O ring that seals the prop bearing carrier to the case.
Now when I put all the seals in I did not use sealer anywhere. Just greased the seal lips and o rings and slid it together. Did I do wrong?
Should I use some form of sealer on the O ring to get it done?
Help...
Help...
