Re: Evinrude 90hp question
Runder
Hello,<br /> A friend of mine has an Evinrude 90HP SNJ0287929. I am looking for the year of it. Also,<br />the trim unit is leaking. Is there a way to fix it without having to remove the whole power head?<br /> Thanks,<br /> Beej
Dhadley
Evinrude and Johnson outboards go by model number. If you get that we can figure it out.<br /><br />The powerhead does not have to come off to remove the trim unit. However the motor may need to come off the boat for the easiest access.
Marc J.
Dhadley is the man. However, I just got finished re-mounting the TNT unit to my 89' 90 hp. I had to service the trim motor and replace the o-rings. It wasn't as hard as it looks. With the motor up and locked, the crosspin out, the center cylinder fully retracted and the six bolts out, the whole thing came slightly up and out.
Runder
Thanks for the response. I was able to get a model number as well. Will this help find me the year?<br /> Thanks again.<br /> Beej<br />model number: e14otrlctb
Dhadley
1983 140 crossflow.<br /><br />Look at all the power you gained already! It could indeed have a 90 hp powerhead though. Is the exhaust plate (plates between the heads) flat or is there a "hump" in it?
Runder
the exhaust plate is flat.
Dhadley
OK. Someone has put a 90 or 115 powerhead on a 140 mid section. No big deal. They use the same midsection.
Runder
I guess good news. I will pass it on. Thanks much for the information, Dhadley. Really appreciated. May be talking to you soon,<br /> - Beej
Dhadley
Youre welcome. We'll be here I'm sure.
