Raw water pump leaking through the weep hole.
huvrluvr
Posted this in a reply on another thread, but figured I should start my own. I have a 05 Larson Senza 186 5.0GL, Overheated because I was lazy and wanted to see if I could get another trip out of the impeller, replaced the Impeller and realized that it was leaking through the weep hole. I then replaced the shaft seal next to the impeller and I still have a leak through the weep hole. I put seal lube on the seal, should it be installed dry or use the Glycerin (ordered 2 seals in case I screwed up).
Does anyone know where I can buy the rebuild Kit for the impeller?:confused:
