Quicksilver Perfect Seal, 101 grease and spline grease?
IanFS
I'm not entirely sure if this is the right place for this but I 've checked out the other forums and my questions is about Quicksiler products.
Quicksiler Perfect Seal, 101 grease and Spline Grease are all difficult to get in the UK.
2-4-C is readily available so could it be used instead of Spline Grease or 101?
Also what is Perfect Seal, is it an RTV or something else? I understand that Permatex is an equivalent but again not easy to get over hear.
Would Sikaflex 291 be OK? Or something similar?
Don S
Re: Quicksilver Perfect Seal, 101 grease and spline grease?
24C is what was used years ago for the coupler, and will work. The spline grease is just a more job specific grease that lasts longer.
Forget Sekaflex, it has no uses on the engine and drive.
I have no clue what is used in the UK to replace Perfect seal, but around here, good ole Permatex Aviation Form a gasket works. Check locally and see what your local mechanics use. It is NOT an RTV.
http://www.permatex.com/products/au...tex_Aviation_Form-A-Gasket_No_3_Sealant_a.htm
