wire2
Thread starter- Joined
- Jun 25, 2007
- 1,584
I have an alpha gen 2 outdrive, tried to put a Quicksilver prop # 48 16548-23 prop on it, and the blades hit the trim tab.
The shell appears to be a bit too far back on the hub, as the machined recess is ?" out of the housing, and the bronze hub and aluminum shell were flush with each other. I put it in a 12 ton press, pushed it in 1/8" farther and it won't go in any more.
Does it need to be heated to go in another 1/8"? That will give me a proper recess on the thrust washer lip, but it may still not allow the blades to clear the trim tab.
Anyone? Thanks.
Anyone? Thanks.
