QuickSilver Control Box Throttle Button Jammed - Advice Please
rmajoran
Hello,
I own a Princecraft Pro Series 169 with a 45 HP Mercury Outboard (1988, Model # 1045412BC).
Attached to the engine is a Quicksilver control box. I'm not sure what model # it is, but when I open it up, it has the numbers 85892.
The throttle on the control box seems to be seized up. I tried WD-40ing it like crazy, but although it loosens it up slightly, it doesn't seem to have any affect. The button will never go fully in. The only way I can currently get the engine started (cold) is by choking it and putting it into gear. Obviously, I would much rather start the engine using the throttle so that the engine can remain idle.
So I'm left with 2 options, which I would appreciate some feedback on:
1. If you've ever had this issue with this control box, can you tell me how you fixed it?
2. Alternatively, can you recommend me another control box that would be similar / compatible with this engine (and where to purchase it)?
I have attached pictures of the Quicksilver control box.
Thank you in advance!
Sincerely,
Ray
rmajoran
Looks like you have the one in the link below
http://www.mercruiserparts.com/Show...c=Commander+2000+Remote+Control(16900+Series)
I would suggest using lithium grease and not WD40, you need lubrication and WD40 is not a lube, it's a water displacement liquid. Suggest taking the plates apart and re-lube.
If all else fails go look up outboard throttle control with side mount and there are several to choose from.
AllDodge - Thanks! Very much appreciated.
Do you have any specific outboard throttle control with side mount that you'd personally recommend?
gm280
rmajoran, before abandoning your control unit, if you are a little mechanically inclined, remove it and disassemble it and rebuild it after cleaning and lubing, I had one exactly like that and it worked for years and years. It isn't that complicated. Look for a break down on some of the boating sights and you can see how everything works together and even possibly buy replacement parts if needed. I like that control unit myself. If I didn't have a Johnson engine, I would absolutely use one of them...
