Quick transom question
Bearsball68
Replaced transom on a 59 Texas Maid.. It has two drain tubes. After I drill out the holes, what do I use to replace those tubes I took out. Thanks
Woodonglass
Re: Quick transom question
Brass Drain tubes. Get em right here on iBoats...
http://www.iboats.com/Seasense-Drain-Tube/dm/*******.997872697--session_id.748148040--view_id.485111
If this is an Aluminum Boat then use Aluminum Tubes. Regardless if its, Tin, Wood, or Fiberglass use 3M 5200 Sealant to install em.
Here's how you can make your own Installation Tool.
Bearsball68
Thanks for the quick response.. I just don't have time to read all the threads on transom repairs.. Is the 3M 5200 what I should for the all the screws that go through to tie the transon back together..
Woodonglass
What Boat is this? Tinner or Glasser? Pics would be a great help.
Bearsball68
59 Texas maid aluminum
Woodonglass
The 5200 would be the product of choice to seal all holes made in the transom.
