M.A.CCruiser
Thread starter- Joined
- May 14, 2012
- 68
#1
Yesterday 09:16 AM by M.A.CCruiser
Very excited because I'll be getting my boat back from my mechanic this Friday after a new long-block install. (mercruiser 5.7 alpha 260hp). New manifolds and risers will be done already as riser failure is what caused the need for a new long block to begin with.
So here are my questions to make sure I cover my bases before I break it again: --
--1. What questions should I be sure to ask the mechanic before I put it on the water and accept delivery? I've been researching new long block installs and there is information about priming oil pumps, is it flat tappet or roller (probably should have already asked this, but didn't know there could be a difference on the same engine coming back) timing settings, carb tuning etc. So those questions I know to ask and say "Have you *insert question here*". What else should I ask?
--2. Check me on my Break-In knowledge - Good Lord there are so many different schools of thought on this- from "Just run it like normal, but vary the throttle and don't stay at WOT, just tap it there from time to time" to "Start it up and fast idle for 20 minutes before even putting it in gear, then vary throttle between 1500 - 2000 for the first hour..." Luckily getting it back Friday, and our Daughter is going out of town this weekend. So the lady and I are going to get out and waste fuel/break in the engine pretty much all weekend. With any luck will get in the 20 hrs and then have the marina give it a 20 hr service and be ready to go. If i understand my research - then if it is flat tappet I need to be gentle to break in the cams and do the fast idle/throttle vary, 1/3rd max for first 5 hrs, 3/4 max for next 5 with a few WOT hits. If it is roller then I should be a bit rougher on it to avoid cylinder glazing and properly get the rings seated.
Thought this thread could also be useful to anyone else getting back after a new install.
Thanks again everyone!
