Quick OIL PAN gasket question
CaptainMak
I've looked thru the manual but can't seem to find the diagrams of the thin metal pieces that run between the block and the oil pan gasket. They lay right on top of the gasket and get sandwiched in-between the actual block and oil pan gasket.
Anyone know what they're for ? Should they be there or can I toss em for a better seal ? :confused:
Bt Doctur
Re: Quick OIL PAN gasket question
That's because they don't go between the block and gasket. You install the gasket, then the pan ,then the 2 metal strips, then put the bolts in . They are supports for the pan when you tighten the bolts .
Bt Doctur
Its starting to really suck not being able to post a dam diagram.
go to double you, double you, double you boat dot net ,plug into the fisrt 5.7 column and you`ll see part # 15 and 16
CaptainMak
Thanks guys. I learned the hard way. Block out, replacing it now. One thing to remember: don't work on something like this drunk, late at night, and while rushing.
Thanks
