craze1cars
Thread starter- Joined
- Dec 26, 2004
- 1,822
Hello,
After a fairly comprehensive tune-up completed over the winter (plugs/coil/wires/cap/rotor/set timing/compression test/rewire and/or clean all connections), my boat is now running like an absolute top. One last nagging little annoyance I'd like to dial out...some minor sooty residue that I find on my transom after pulling it out of the water.
It does seem a tad rich at idle...so I'm gonna systematically start tweaking the carb's Choke and/or idle mixture screws. I went to the garage today to document my starting points.
1999 Volvo 5.0GL PWTR, 2 bbl Holley carb, all stock. Factory says base setting for idle mixture screws is 3/4 to 1 turn out. I popped the caps and checked mine. Starbord side was 1 turn out. Port side was 1 and 3/4 turns out. Hmmmmm. Likely be my reason for rich idle? (used boat...I know nothing about the history). So for the time being I just turned that Port side in 3/4 turn so that now they are the same, both are set at exactly 1 turn out. I will see how she runs next time I'm on the water, and I will do some on-water tuning at that time...
My question is this: Is there ANY compelling reason that someone would have set one side differently from the other on this carb? Manual says they should both be set the same...but I know the realities of tuning sometime cause us to need to deviate at times.
Thoughts? Or am I simply doing the right thing by now just setting them the same and then tuning the idle from there?
Thanks!
Thanks!
