Quick and easy lunches when out on the water
spoilsofwar
Do you just leave it mounted where it's at?
To change the subject a little.. Is the orange cord there to charge the battery? That would be so helpful if that is the case.
Yes, it stays mounted all the time. I just swing it out over the water when I'm using it.
The orange extension cord is for the onboard battery charger, yes.
Drew220
An on board battery charger is really easy to add and is really helpful. I just added one to my boat and hook it up with an extension cord at the storage yard. Keeps both of my batteries fully charged. I don't have a plug on the back yet but will add one soon.
Also West Marine had the Magma Cabo grill as their Friday deal of the day a few weeks ago for 125.00. I'm kicking myself for not picking one up.
KnotConnected
Smoked salmon and jerky are both great. chicken breast can also be a good on-the-water meal. When served cold, its a bit more palatable with some sauce like a honey mustard.
64osby
fetch
Another Magma vote. Grilled food adds so much to the day or a sunset cruise.
KnotConnected
A few questions for you kats with Magma (or similar) grills:
1) SpoilsofWar, do you leave your grill mounted when underway, or bolt it up when you're on the hook and want to grub?
2) Do they collect a fair amount of junk, like burnt food, ash, grease, etc.. that would make removal and stowage inside the boat messy?
3) Any concerns about grilling over expensive-to-replace vinyl seats, or near 120+ gallon fuel tanks?
spoilsofwar
1. I leave mine mounted at all times. I've never had any issues with doing this, and I've been in some bad storms with it. It's been mounted just like you see in the pictures since early 2012, and only removed for cleaning. If you go to the Magma website and look at their vast array of mounts, the specs list which ones they recommend for use underway and which are supposed to be stowed when underway. I'm not even sure which mine is rated for, and at this point it doesn't matter to me because it just plain works.
2. I think the answer to this question depends on the style of grill you get. For my kettle, depending on the type of food cooked, it will collect grease drippings on a plate below the main kettle, where the Venturi gas tube passes thru. Mainly this is with fatty things like hamburgers. It's not excessive, but this is one of the reasons why I swing the grill out over the water when it's in use (the other being that it gives me room to sit next to it and work the grill). I clean the grill by simple hosing it out every now and then. Being stainless, you won't harm anything. I'll even admit to completely dunking it in the lake when I wanted to clean it during a camping trip.
3. As long as you have some clearance (I would say no less then 6"-8") between the grill and vinyl, you will be fine. You can see the proximity between my grill and the vinyl covered sun deck... The vinyl is unaffected. What you can't see is that it's also about 18" from the engine compartment blower outlet (on the port side hull under a cowling) and about 3 feet from the gas fill port. You're using this item outdoors, with fresh air circulating all around; it's not going to blow you up. How close to the gas tank could you really put it, anyway? Some people may say this is dangerous, but I have 4+ years of empirical use to back me up saying it isn't. Now, I wouldn't recommend grilling while you fuel the boat and run the blower, while simultaneously smoking a cigarette, or any other potential Darwin-award winning actions. But you're gonna be fine in normal use, just like all the other boat grillers I see on my lake.
Hope this helps.
bruceb58
I have a round Magma for my Wellcraft and a square grill for my pontoon. Way prefer a square grill to a round one if a square grill will fit.
My Magma mounts with a fishing pole mount. I custom made a mount for my square grill for my pontoon.
Both my grills mount so that they hang over the side of the boat when in use. I would not mount them so they are over vinyl.
KnotConnected
Nice! And I suppose it's safe to assume that the magma gas grill is way more practical than trying to fry some kebabs over the alcohol burner in my galley?
bruceb58
My square grill is a Kuuma 160 Stow and Grill. Less money than Magmas and built better in my opinion. Owning both, Magmas are overpriced for what you get.
It also has foldable legs so you can use on shore on a table too
bruceb58
Except for the part that you can't get many kabobs on a round grill!
spoilsofwar
Agreed. They are priced as a premium name brand, with the recognition that goes with being the "first" to do something on a wide scale. A prefect analogue to this are Yeti coolers. They work awesome, but there are now brands out there that work just as good for half the price. Kuuma has come along now and their grills are a great choice. I'm not sure if they even existed when I bought my Magma, but if they did I'd never heard of them.
SkaterRace
Master Chief Petty Officer
I mostly do sandwiches and fruit. Nothing fancy but I have a small space to pack it into so less is more.
64osby
I set mine up when wanting to grill, it stores in the flip back seat storage compartment. Has a bag that it all fits into and keeps any mess off the boat.
Always grill over the gunwale so nothing gets on the boat. I picked mine up at an auction and paid less then $50. I made the custom mount for the boat.
