kycoalminer
Thread starter- Joined
- Mar 24, 2018
- 6
I have a 1971 johnson 50 hp on a 17 foot bass tracker , been working on it for the past year. Rebuilt carbs, new coils, new fuel lines, new water pump. Problem I have had is it doesn’t want to open up at wot . Done a compression check it was good both cylinders are even. i brought a Sierra power pak. Put it on and still had the same problem. So I continued doing some more checks. Check the spark it’s not blue but a orange color. Took a test light and took off the coil terminals off the power pak and tested it and had no light. It’s a brand new power pak. Could it go bad that quick? How could I get spark at my plug wires but the power pak that’s feeding the coils does light up with a test light. . Could the stator cause a power pak to burn up.
