Question on Mercruiser 165 Front Engine Mount
Twolane
If someone is familiar with a difference I'm seeing here thanks for whatever insights you might offer. Question is:
Have a new to me old Glastron with a Mercruiser 165. Now that it's here and giving it a little freshening up old boat parts/ideas/requests for rides/etc etc etc are coming out of the woodwork from friends and family. One such help offer deals with a potential spare engine from a similar vintage Invicta.
Engine is also a Mercruiser 165. Hour meter shows 2200. It's all clean and shows good compression. No reason not to grab it just to set aside (since it's free). Except for one difference.
My engine has engine block casting that extends beyond the timing cover on both sides which are the mount locations for the front motor mount. The engine that I'm being offered does not. The casting on the engine's left side has the two bolt holes. On the engine's right side, however, it's obvious that part of the casting was never there. Block follows the countour of the timing cover down to the oil pan.
Now here's the kicker. The engine still was mounted in its old boat with a front mount. It used a heavy steel 90 degree bracket that bolted to an engine casting boss down by the oil pan. The bracket makes the 90 turn uphill and runs beside the timing cover where the front mount bracket attaches to it with two nuts and bolts.
Obvious question is "is this ok?" In some ways the engine may answer this itself as its apparently been this way for 2200 hours. My cousin who had the boat has no recollection of the engine ever being out. It just seems odd that the bracket would be used and let the engine hang from a single engine boss on the right front rather than use a different casting that has two mount holes right in its face.
Bt Doctur
Re: Question on Mercruiser 165 Front Engine Mount
someone dropped a car 230 or 250 cu.in into it.
Twolane
Have seen the casting with all the bolt holes in some automotive uses too. Chevy had some a/c brackets that bolted on the right side down there. Different foundries must have had different molds. Interesting.....
Ok, here's another question on the same engine. This engine came over this evening. The old boat it was in was dead so he cut the transom and brought it all in one large hunk. The two bolts/pins that attach the bellhousing to everything behind it; how the hell do they come out?
Have followed instructions in the manual. Have tried only thinking inside the box (to be safe). After that didn't work tried thinking outside the box (didn't do any better). What's the trick and/or method to removing them so can finish separating the engine from the rest of the butt end?
