Hello, I recently purchased a 96 Ebbtide Fish n Ski and I have a simple question.
There are two battery spots, only one is installed at the moment and I want to add a second battery, not for use of the trolling motor but just for redundancy and as a backup to my primary starting battery.
There is an electrical panel in the bow for the trolling system. One of the switches is a 3-way toggle. It is labeled as follows:
Charge 2 -12v. I assume in this position it is charging both batteries.
12v. I assume in this position only the primary starting battery is active.
Run 12/24v I assume in this position both batteries are active.
Also there are two pairs of wires running back to the second battery tray. One positive is labeled trolling battery one positive and the other red wire is labeled trolling battery two negative. How do I wire these in?
Thanks
Thanks
