UncleWillie
- Oct 18, 2011
- 3,995
Re: Question about necessity/importance of depth finder
GPS elevations are less accurate than GPS positions.
On a good day a GPS might locate you within 25 feet.
This is just fine for locating anything on the water.
If I intend on avoiding something, 100 yards is all the closer I want to get.
100 yards +/- 25 feet is workable in my eyes.
Locating a channel entrance buoy within 100 feet is acceptable.
But I would never attempt to navigate a 200 foot wide river, completely blind in fog wth just a GPS.
Using the GPS elevation to compute the water level +/- 25 feet is not of much use.
The aviation world is happy to know their elevation within 100 feet, but would never consider using GPS to determine any altitude.
They will use it to find the airport, but not the runway!
If you use a depth finder in conjunction with up to date charts and use elevations from your GPS you can pretty well know what the depth of the water you're in and headed for is. ... If you have GPS the NMEA 0183 sentence contains the elevation and most chart plotters use it. The first step is to get the current elevation on the body of water minus the distance from the antenna to the water line. Then you subtract the elevation at the time of mapping and the difference can then be used to compare to the contour lines or depth numbers of the navionics map. I do this once when I arrive at my favorite lake and put a sticker on my plotter with the correction number.
For instance: My favorite lake was mapped when the lake surface was at 5101.7 feet. The current lake elevation is 5096.3 feet. The difference is 5.4 feet so I look at the Navionics Map on my Plotter and if it's normally 10 feet deep its now 4.6 feet. That rock pile that was always 6' deep and easily clearable is now a prop killer.
