Question about my Mercury Mercontrol Remote! just 2 questions please
y2jericho
My mercontol remote from my 1970 Mecury Thunderbolt Ignition 650cc 65hp .. Has a little plug thing opposite the ignition. It is around the same place just over on the other side and i do not know what it is for the holes kinda look like this<br /><br /> / \<br /> ___ <br /><br />or <br /><br />| |<br /> _ <br /><br />I also have an hours meter and other items which i wan't only to be turned on when the engine has been started so its not draining power beforehand! How do i do this?
superman
Re: Question about my Mercury Mercontrol Remote! just 2 questions please
Sounds like your describing a tach plug used in some applications. As for the hour meter you would need to tap the power leades thru diodes to the stator side of the charging bridge rectifier.
Jumper
I've got the same plug on my Merc Control and if I'm correct, it's to plug a Tachometer. <br /><br />As for your gauges, do you have a "power" switch for the console? On my console, I have a switch that sends power to the console so the lights work, the bilge pump works, ect.
ODDD1
Jericho, if you go to a merc dealer that has been around awhile, you can get a wire harness that plugs into that socket on your mercontrol...3 wires in the harness, a positive[+] a negative[-] and a tachometer sensor wire...the + and - can be used for a dashboard mounted hourmeter, or other guages...it is 'key on' power.......
y2jericho
yeh looks like a tach connector to me to :D <br /><br />Also isn't an hours meter supposed to check how long the motor has been running or how long you have been on the boat?
y2jericho
And yep i am buying a console thing for my little 14.4 foot boat! So you saying i really should just let the hours meter when i press the switch? So when power from the battery is being used the hour meter at the same time.<br /><br />Or maybe i hook up a switch re routing the + line from the battery to my dashboard and then goes back to my motor so when the button is switched the battery is activated and it THEN starts the hour meter automatically and then with the switch being on i can also turn on my motor as power will be feeding to my motor and console switchbaord for my lights, radio, speedo lights, fish monitor, etc. :) <br /><br />Thanks
y2jericho
EVEN BETTER O'DD :D lol<br /><br />I have a stewart warner tachometer! and it has 2 wires on the back... One is RED and One is BLACK what one would go in the other connection ? as the + and - are used for power?<br /><br />Is black like earth and red is the sensor connect or something? <br /><br />Thanks
chrismercury
what is a tachometer? :confused: <br /><br /> thanks
