Question about grinder blade???
scott11
Hi guys,
This is my first boat rebuild and im in the process of sanding down the left over firberglass that held the deck and stringers down. I was wondering if anybody could tell me what a good grinder blade is for this job? I got as close as possible with the cutting blade but there is still a little bit left.
Rickairmedic
Re: Question about grinder blade???
Scott you want a flap wheel for the rest Home Depot and Lowes usually stock them in the same area as the regular grinding wheels ( these look like a disk with heavy sandpaper fanned out on it .)
Rick
scott11
K thanks Rick. I also forgot to ask if there is any specific grit that works best?
Rickairmedic
Scott I would go with a 40-60 grit and be very very carefull so you dont burn through :D. You will get the hang of it pretty quick just take your time and keep an eye on how far you have gone and youll be fine :D.
Rick
andgott
Master Chief Petty Officer
I also find fiber discs on a backup pad helpful- The replacement abrasive discs are only $1.50 ea, as opposed to the $5.50 or so for a flap wheel.
scott11
Do you go through quite a few flap discs when sanding fiberglass? I was also wondering if i need to sand right down to the hull or if its ok to leave some of the leftover fiberglass?
