Quart?
murraygw
Will a quart of primer cover inside and out of thi boat. Or should i get a gallon
Re: Quart?
A Quart of paint Doesn't really cover very much,..... Even when Thinned to be sprayed....
I Don't Think you'll have awhole lot left if you get a Gallon........
Yacht Dr.
Re: Quart?
murray..when you talk QT of Primer ( not paint ) are you talking mixed QT..or unmixed ? I mean..after you catalize and reduce..your more into 2 qts..which will be fine if your not blowing it at 40psi..
you need about 2-3 qt Paint to finish it with a conventional gun m8..( depending on the paint of course )
YD.
murraygw
Re: Quart?
i am going to use a brushable thinner and bush and roll primer. I hope to spray Top and bottom Paint. I was going to order a quart of top and bottom and a gallon of primer.
murraygw
Re: Quart?
True Dr. If tou looked that pic will a quart of topside and a quart of bottomside do the job or will i need more that a quart of each?
Yacht Dr.
Re: Quart?
YD.
I allready asked you..is this mixed or unmixed ?
you need 2 Qts of mixed primer..and 2-3 of paint..once again..depending on your paint..
YD.
