QD19 upper crankshaft seal
Starcraft1210
Hello all here on iboat! Newbie to the forum so be nice!
My 1958 johnson seahorse 10 was running great then it started missing and died! I limped back to the ramp on the trolling motor and loaded her up. I popped off the flywheel as soon as I returned home and found a horror story! It seems the spring under the cam chewed half way through the cam!
Now, I also found the graphite seal was in many pieces and suspect a hunk of it came out and lodged under the brass retaing washer and increased the pressure of the spring burning out the upper retaining washer and aloud the spring to eat the cam.
I bought new seal, o ring, retaining washers, spring and cam with points to reassemble but i do not want to have this happen again so can anyone explain installation procedure of said parts? Do i need to use a certain lube on anything? Did pulling the flywheel blow the seal out? I used a harmonic balancer puller. Any help out there?
F_R
First, pulling the flywheel had nothing to do with it.. Second, damage such as you describe would be so rare as almost unheard of.
O-ring goes inside the carbon seal with enough oil to slightly wet it. Also slightly wet the face of the seal where it rides on the bearing below. Ridge on seal contacts the bearing, making the seal. Next goes the large washer, flat side down, then spring, then small washer flat side up. Then the cam. When the flywheel is installed it holds everything in place. All this is installed dry.
Of course before any of this, pull the armature plate and support rings and degrease and clean everything. Use some EP grease very sparingly on the support rings and neck of the crankcase. Too much grease will simply splatter off and foul the breaker points.
Shaft and flywheel tapers must be absolutely clean and dry and torque nut to 40-45 foot pounds (important). Not saying it happened, but too much torque can spread the taper and allow the flywheel to go down too far. I have no idea if that caused any damage or not. On the other hand, too little torque will shear the key and cause major damage. Did I say important?
Starcraft1210
Thank you F-R for your time and knowledge.
As for the carbon seal, it has 2 notches 180 degrees apart on one face, i take it that side faces up? I just picked this QD up in the spring after the failure i pulled the flywheel. When the flywheel came up it did so with a heck of a pop, i left the nut on flush with the end of the crankshaft, and thought maybe thats what broke the carbon seal. The seal came out in 7 pieces and both retaining washers were just little rings,and i mean almost nonexisting. What i do not understand is, does the carbon seal washers and spring rotate with the crankshaft? I imagine it does and failure is due to it not rotating with crankshaft. Why? Thanks again for everything!
